Where can I get Phosphoric Acid
drizler
11-09-2001 20:42:46
Where can I get Phosphpric acid by the gallon? I have looked at all the paint stores and hardware stores in the area and they thing I am from Mars. The only stuff I found was the overpriced solution used for auto painting and a chemical supply house with lab grade stuff for $75/ gallon.
J3nut
11-19-2001 05:12:50
 Re: Where can I get Phosphoric Acid in reply to drizler, 11-09-2001 20:42:46
I found some at my local hardware under the brand name OSPHO. It was priced at $12.00 per qt or $22.00 per gallon. I bought a gallon and as thin as the stuff is I think it will go a long way.
Mark
Jerry B
11-12-2001 08:12:03
Try Muritic acid. The same basic thing and works exactly the same way. Easier to find also.
Franz
11-12-2001 21:42:06
 Re: Re: Where can I get Phosphoric Acid in reply to Jerry B, 11-12-2001 08:12:03
Are you KIDDING, the only similarity is the word ACID.
Muriatic will eat rust and clean iron, but it will also hide in the microporoscity, and cause rust to return.
Phosphoric will convert rust {Iron Oxide} to Iron Phosphate.
Jerry B
11-13-2001 06:34:25
 Re: Re: Re: Where can I get Phosphoric Acid in reply to Franz, 11-12-2001 21:42:06
Franz.
It goes without saying that Muritic acid has to be neutralized. Baking soda works well if left in contact with the metal for several minutes.
The only problem is after washing for the last time yoiu can get a flash rust over the bare metal, but it wipes off easily. I have never had a proble using muritic acid.
Bill L
11-17-2001 16:47:12
 Re: Re: Re: Re: Where can I get Phosphoric Acid in reply to Jerry B, 11-13-2001 06:34:25
Several liquid toilet bowl cleaners use Phosphuric acid and not Hydrochloric acid. Works fine
Lewis
11-12-2001 20:36:36
Doesn't the muriatic acid have to be neutralized after application. I read a post from a guy who used it, and after a period of time, the acid let the rust form underneath the paint. I have tried the phosphoric acid on the Farmall 100 I am preparing to paint and it seems to work great.
Franz
11-09-2001 22:08:20
We buy it 85% strength from a chemical supply house, USP grade. We dilute that about 10 -1 with water. Thanks to OSHA and other government do good agencys, you'll usually have to buy a chemical weight container the first time you buy the acid.
You can also buy it as "metal prep" from body shop suppliers, in ready to use strength, as well as Home Depo.
If you have a friend at CocaCola, it is a primary ingredient in their fine beverage.
Franz FYI
11-23-2001 01:18:48
 Re: Re: Where can I get Phosphoric Acid in reply to Franz, 11-09-2001 22:08:20
Franz,
You would change your tune if you had a consumer weight container break and spill acid, resulting in severe chemical burns!
