Brush painting
Scott
12-12-2002 09:40:16
I am considering painting my tractor. This is a working tractor so the look is not all that important, just want something durable. After reading most of the post here, I see that using a hardner will help the paint last much longer. I plan on brush painting the tractor (do not have an air compressor) with the exception of the sheet metal (will send that out), does the paint need to be sprayed for the hardner to work correctly or will the hardner do it job just fine brushing the paint on?
TIA!
Rod (NH)
12-12-2002 21:31:14
 Re: Brush painting in reply to Scott, 12-12-2002 09:40:16
The use of a "hardener", so called, is to cause curing of the paint film by chemical reaction rather than oxidation with ambient air. It improves the chemical resistance of the resulting film, among other things. Brushing or spraying should make no difference.
Rod
