Electrolysis
Doug(MN)
11-10-2001 18:06:00
Hello,I been reading posts about electroysis, my father in-law been doing this for a while now. works great. been doing a little researce on the subject and found a good web site.
www.bhi.co.uk/hints/rust.htm its worth a look
hope this helps
Doug
Curt K.
11-11-2001 17:06:35
 Re: Electrolysis in reply to Doug(MN), 11-10-2001 18:06:00
Has anyone tried this process on rusty manifolds. Does this eat any of the metal or just the rust. If I do this on the manifold there may not be much left to direct the exhaust.
Franz
11-11-2001 22:08:10
 Re: Re: Electrolysis in reply to Curt K., 11-11-2001 17:06:35
The process does NOT eat metal.
The easiest way to think of it is in terms of electroplating. You are electroplating the rust onto the anode, and no iron will follow it.
If the manifold is good under the rust, you'll wind up with a clean manifold, slightly thinner, because the rust will be gone.
