Wheel pitting
Ron
12-14-2002 15:06:47
I would like to know the proper way to remove or reduce pitting on a wheel. Is there a chemical for this? And what to use for primer and paint ingredients? Thanks in Advance. Ron
David
12-15-2002 05:19:07
 Re: wheel pitting in reply to Ron, 12-14-2002 15:06:47
I have a similar problem with two wheels that I've just blast cleaned. Other parts also have pitting but not as bad. I bought a paint called synthetic surfacer which I hoped would help but i'm not sure how to best use it. (hence my posting below) I started with brushing it on and sanding down but I think that will only take small pits out. I'm intending to use body filler in the deeper pits, rubbed down and then, probably follwed by a couple of coats of surfacer which will also get sanded. I think spraying the surfacer will be best if I can get it to do spray. I don't know if that's the best way todeal with pitting but it is one way. If anyone comes up with a better method I'll use that instead!
David
12-21-2002 08:49:52
 Re: Re: wheel pitting in reply to David, 12-15-2002 05:19:07
An update. I tried brushing on surfacer and although its is ok at first, as the surface quality gets better with successive rub-downs, the brush marks start to become more of a problem than the pits and scratches. I will be spraying it in future even it it has to be thinned and get lost of coats.
