Rust pitts
Joshua
12-23-2002 16:58:01
Does anybody know how to fix the rustpitts on a
Farmall C torque tube to paint.
Thanks all
CNKS
12-24-2002 18:15:27
 Re: rust pitts in reply to Joshua, 12-23-2002 16:58:01
I have never seen pitting on cast serious enough to fix. Cast is rough anyway, some of the casting imperfections look worse than the pits. You can do what the post below says, or you can fill the worst ones with body filler,or JB Weld. Problem is, if you do fill them in and sand smooth, the areas you repaired won't look like the rest of the cast. Cast isn't supposed to be perfect. Unless you have big holes (torque tube -- battery acid?) I would leave them alone.
David
12-26-2002 14:12:40
 Re: Re: rust pitts in reply to CNKS, 12-24-2002 18:15:27
I agree with not fixing pits on cast. It always seems to look artificial. I have heard it said that spraying it "orange peel" effect helps to make it look more like cast again but I have always just left the cast alone and made sure the tinwork looked good.
David
12-24-2002 09:20:38
I'm not sure I actually can claim that I know how to fix them but I am trying to do the same on wheels and tinwork at the moment.
The method I am using is (i) sandblast (optional) (ii)etch prime (iii) spray with red oxide primer (iv) fill worst of pitting by smearing body filler over it with plastic scraper (v) rub down and repeat till surface is reasonable or else you're totally fed up with doing it (the latter will probably arrive first) (vi) spray with surfacer (a thick paint basically) rub down and respray surfacer again until you get fed up with it - eventually you might get a surface that is good enough to finally wet "flat" with 400 grit paper. (vii) spray topcoats.
It has worked reasonable well on a dash panel so far for me but some people don't like to use body filler and there may well be other ways to do it. I want to get a reasonable job but am not in search of total perfection.
