Primer Help
Phlogiston
02-01-2003 19:32:20
I am about to prime a bumper that I have prepared. I have a can of red colored primer called "X-O Primer" for metal. It is supposed to kill rust. My question is, can I sand this primer, or must I go buy some regular sandable primer?
Thanks.
611b-aNDY
02-02-2003 12:16:25
 Re: Primer Help in reply to Phlogiston , 02-01-2003 19:32:20
Most rust coatings do not allow sanding. This is because it will break the surface of the coating allow oxygen to get back to the metal. I use an etching primer, followed by Dupont gray Primer/surfacer. Then you can sand along as you don't cut through the rust primer. If you are trying to smooth out a rusted part I found this to be the easiest. If you do sand through, life is OK. I haven't had any problems with rust coming back.
