Question on paint and primer
Adam
02-02-2003 19:13:13
I have heard some guys say they paint and primer and do not use a clear coat, some say they primer paint and clear coat, and some only paint and clear coat. This is my first time painting a tractor and i don't know which way to go. Any input would be appreciated. Thank You. Adam
Rod (NH)
02-02-2003 21:35:29
 Re: question on paint and primer in reply to Adam, 02-02-2003 19:13:13
Hi Adam,
There are probably as many opinions on painting as there are people making them :o).
If you are new to painting, I would recommend using a two part epoxy primer and a single stage synthetic or, preferably, acrylic enamel without hardener. No clears. Single stage paints do not require a clear coat for gloss. If it doesn't specifically say "basecoat" on it, it is a single stage paint.
Two stage paints consist of a basecoat of color plus a clear. The basecoat is a very thin and flat film that only provides the color. There is no gloss until the second stage clear coat is added. Most all automobiles have this two stage paint system on them nowadays. Clears can also be added on top of single stage paints for an increased "depth" effect. I have used clears on top of single stage paint because I think it makes decals look more like they are painted on...it tends to smooth the otherwise sharp edges of the decal and "blend" them into the surrounding paint.
There can be considerable disagreement on the safety aspect of using hardeners and clears. Both hardeners and clears have especially toxic chemicals in them that should not be used without special safety equipment, in my opinion. New painters are unlikely to have such equipment, which can be fairly expensive. I therefore hesitate to recommend using these materials without knowing available safety provisions, even though they are generally considered to provide a "better" and more durable paint film. Do searches on "isocyanates" and "hardeners" in this forum for specific discussions on this subject.
Rod
CNKS
02-03-2003 19:06:24
 Re: Re: question on paint and primer in reply to Rod (NH), 02-02-2003 21:35:29
Rod -- I don't fully understand your post. You are telling him to stay away from hardeners and clears, yet the 2 part epoxy primer I have used has hardener--thus the two parts. Am I missing something? I use hardened primers and hardened topcoats with a supplied air system, but am confused about the 2 part epoxy you mentioned. I am fully aware of the dangers of isos.
Rod (NH)
02-03-2003 20:56:43
 Re: Re: Re: question on paint and primer in reply to CNKS, 02-03-2003 19:06:24
Hi CNKS,
The second part (catalyst) of the epoxy primers that I am familiar with is not urethane based and does not contain isocyanates. Epoxy is the only case that I know of where that is true.
PPG's DPLF epoxy primer is the higher-end product in PPG's line. It uses either DP401LF or DP402LF as the second component catalyst. PPG's OMNI MP170 epoxy primer is the economy product in PPG's line. It uses MP175 as the second component catalyst. The MSDS for this product is available at the link below. The MSDS for the others are also available at the PPG website.
You can see in the MSDS that the recommendations for respiratory protection is EITHER an air purifying (cartridge type) OR a supplied-air respirator. If you check out the PPG MSDS for a topcoat or clearcoat hardener, including a hardener for the "2K" primer surfacers, that will not be the case. In those instances, isocyanates are involved and ONLY the supplied-air is recommended specifically in the MSDS.
I don't know about the DuPont products. In the past they have been pushing the etch primers rather than epoxy but I see they now have an epoxy one. I forget the designation and I haven't checked out the associated MSDS but I would not expect it to contain isos.
If you (or anyone) know of any two part epoxy primers out there that DO contain isos, please advise. I certainly don't want to mislead anybody on this important safety point.
Rod
CNKS
02-04-2003 09:12:57
 Re: Re: Re: Re: question on paint and primer in reply to Rod (NH), 02-03-2003 20:56:43
Thanks -- I've already read the MSDS and also the cans and did not pay any attention to the either/or stuff. I'll probably use my supplied air system anyway. I was under the impression that all hardeners have isos. Actually, about any paint product or related product such as DX 330/440 has that warning, although I just wear a mask with these.
Rod (NH)
02-04-2003 16:25:52
 Re: Re: Re: Re: Re: question on paint and primer in reply to CNKS, 02-04-2003 09:12:57
Oh sure, if one has supplied-air equipment why not use it, even with the epoxy? I do. Just because the product doesn't contain isos doesn't mean the stuff is good to breathe. It's not. Some type of respiratory protection is almost always called for beyond that provided by a simple particulate mask. My recommendation was based on the fact that I think it is unlikely that persons new to painting are fully aware of the special safety issues in using urethane products requiring hardeners containing isos. I also believe that most in that situation would like to avoid spending $400 or more just on a respirator to safely paint their tractor. With a careful selection of materials, admittedly not the "very best" (except for the epoxy), they can do a quite decent job while protecting their health with a relatively inexpensive chemical cartridge respirator.
CNKS
02-04-2003 09:01:32
611B-Andy
02-03-2003 19:05:26
Agree with Rod 100%
