Phosphoric Acid
Jeff Scott
02-05-2003 16:00:07
Hello all. I've been reading several of topics at this site and a big question that I have is on phosphoric acid. I've seen people mention it for unsticking an engine and also for taking off rust for body work. Where and what strength do you want for this? Are there temperature restrictions when applying it? How long do you leave it on for? What other considerations come into play when using it? Don't mean to seem stupid but all of this is new to me. Thanks.
CNKS
02-06-2003 19:22:53
 Re: Phosphoric Acid in reply to Jeff Scott, 02-05-2003 16:00:07
I wouldn't use it for unsticking engines, although it is a weak acid, compared to hydrochloric (muratic)acid, and sulfuric acid, etc. For other purposes it goes under various tradenames. Metalprep is the only one I can think of now, ask for it at an auto paint place and follow the instructions on the container. Some versions need to be washed off, some need rust to work, and are left on, even used as primer in some cases. I prefer to remove the rust first, use a rust converter/preventative and then paint. See my response to the post above.
