HELP! Novice Painter
Devin Brewer
02-16-2003 20:50:14
Let me preface this by saying I am a novice painter.
Recently I restored a 1967 JD 4020. After the mechanical work was finished the tractor was cleaned thoroughly. I then primered the spots where the paint was completely worn off. My problem is this. I followed the directions on mixing (paint, thinner and hardner) spray pressure etc. I used enamel paint. The temperature was between 50 and 55 degrees. (This was fine by the paint specs.) I painted the tractor with a fairly thick base coat and covered it thoroughly. The paint went on fine and no problems. It look great. I returned to the shop approximately 8 hours later amd found that the tractor had condensation on it and the paint looked extremely flat with no gloss. The tractor was painted indoors and remained indoors. The temperature variation was probably no more than 10 degrees. Is the condensation the reason for the flat paint or did I do something else wrong? Any advice would be appreciated. Thanks alot!
Devin
Rod (NH)
02-16-2003 22:00:59
 Re: HELP! Novice Painter in reply to Devin Brewer, 02-16-2003 20:50:14
Hi Devin,
Boy, 50-55 deg is awfully cold for painting. Most automotive enamels use a fast reducer at cool temps and usually are not recommended below about 60 deg. However, if that was on the label, it is probably not your problem. I am having some difficulty trying to understand how you could get condensation inside on a day in the winter when the humidity is typically quite low. Do you have anything adding moisture to the air that would condense on cool surfaces? Did you notice any condensation on other metal surfaces that were about the same temperature as the tractor? Was the surface temperature of the tractor the same as the air (and paint) temperature when you applied the paint?
I have experienced the dulling you mention after painting outside and leaving it outside in the late summer or early fall when a dew is present after dark. So condensation can certainly cause it to dull. It is unlikely to be uniform though. Make sure you used exactly the correct reducer and hardener that was specifically recommended by the manufacturer of the paint. That will eliminate any possible chemical incompatibility.
I corrected my similar dulling by using a rubbing compound (power compounding) on the areas that had the condensation. You can try that, since you used the hardener. If it is all over, even in hard to get at places, you might find it easier to simply scuff sand with 320 or 400 grit and recoat. After you determine what the problem might have been, of course.
Rod
