Painting Over Fiberglass
AWB
03-02-2003 07:14:17
If I use a fiberglass patch to repair a piece of sheet metal that is too thin, how do I prepare the finished surface so as to be able to use regular Rustoleum machinery enamel on it? Thanks.
Fred Kobs
03-04-2003 01:14:06
 Re: Painting Over Fiberglass in reply to AWB, 03-02-2003 07:14:17
saw this yesterday but thought someone who knew more would have answered by now. Are you using resin/cloth or the hairy bondo stuff? If the resin&cloth kind, scuff it with 220? but if you break thru the resin(clear coat)you must put on a coat of resin or the raw 'glass WILL show, and take on moisture. The hairy bondo kind I always leave low and bondo over it to finish. I don't claim to be a body man so good luck. Fred
Larry806
03-04-2003 19:18:22
 Re: Re: Painting Over Fiberglass in reply to Fred Kobs, 03-04-2003 01:14:06
NAPA has a fiberglass sealer to use under primer & paint of it will very likely blister Get body work done seal it than prime or paint
Larry806
03-04-2003 19:17:41
NAPA has a fiberglass sealer to use under primer & paint of it will very likely blister Get body work done seal it than prim or paint
