Spray Guns....what does all of this mean???
Jeff Scott
03-12-2003 01:12:04
Hello all. I am new to the board and very new to tractor restoration. I have an IH 3414. I want to buy a spray gun to put a nice finish on my tractor and working trucks. "I" want to paint my tractor if that makes sense and I also later want to pursue autobody as a hobby. I read this board daily and I have researched throughout the archives. I also read the autobodystore BBS and archives daily. It seems like the more I learn the more confused I get. Basically I have narrowed down what I want to the DeVilbiss Finish Line II or an Iwata AZ3. I've read previous posts about the non-metal tip and I don't want to pay a fortune for a Sharpe Platinum. Len at the AutobodyStore recommends this gun as the best bargain. I have a 5 HP Sanborn Magna Force 60 gallon single stage compressor with 300 PSI 3/8 hose. I can not find the SCFM rating anywhere on the tank and nowhere on the internet because Sanbord was bought by Coleman but I read at the Sharpe website that you should get roughly 3 CFM per HP. Basically all I want to do is paint my poor rusty tractor with a synthetic enamel, play and learn without it looking like I used a spray can.
My questions are:
Gravity fed vs. Siphon fed: HVLP and conventional guns come both ways. Is there an advantage to gravity fed over suction? Why are both options available in both types of guns?
SCFM rating: The Sharpe Platinum needs 7.5 CFM at 50 PSI and 10 at the cap or something like that. What does the 10 at the cap mean? I also really like the Sharpe Cobalt but the air requirement is something like 13.9 @ 50 and 10 at the cap. The DeVilbiss Finishline II HVLP needs 11.4 CFM at 23 PSI and the Iwata HVLP needs 13.8 CFM at 29 PSI. From what I gather the lower the required PSI the more CFM your compressor is able to produce, is that correct? So in essence isn't this more or less equivalent to the Sharpe Platinum's air needs? Can my compressor handle the Iwata and DeVilbiss HVLP guns or should I go with a cheap $30 Binks look alike from Astro pneumatic or other conventional guns. But when I look at some of the nicer conventional guns they have some heavy air requirements also because of the high air pressure requirement. I plan to buy a better compressor in the future but I want to paint my tractor first. Is the 3 CFM per HP rule true? Does size of the tank play into this as far as allowing a more air demanding gun?
I plan to order Len's painting 101 video. Can anyone offer any additional advice or equipment that I may need? Thanks in advance
Jeff Scott
03-18-2003 01:45:01
 Re: Spray Guns....what does all of this mean??? in reply to Jeff Scott, 03-12-2003 01:12:04
Gentlemen,
Thank you for your help last time. I paid close attention to your words and have acted upon them. I have purchased a Harbor Freight HVLP gravity fed detail gun, the DeVilbiss Finishline II, and got a terrific deal on Sharpe Platinum from ebay. It was new in the box with the two cups, regulator, wrench, and a 1.1 tip. I paid $213 for it. The refurbished Platinums only come with 1 cup and no regulator.
Please correct me if I'm wrong but I am very limited with a 1.1 tip. From what I've read it atomizes almost too well causing you to be very slow and the surfaces being painted will flash before you're done, and also I can not shoot primer with it. My detail gun has a 1.0 tip. Am I understanding this correctly or is this nothing to worry about?
Jeff Scott
03-12-2003 22:08:59
A special thank you to everyone who shared their knowledge and experience with me. You guys are very helpful and truly awesome. I have learned so much these past few months just reading the various posts from Rod and CNKS. I feel much more confident in my equipment now and I plan to follow the advice that I have been given. One final question...do I need special diameter air hose for any of these guns or will my 3/8 suffice?
Rod (NH)
03-13-2003 14:40:41
 Re: Re: Spray Guns....what does all of this mean??? in reply to Jeff Scott, 03-12-2003 22:08:59
Jeff,
3/8" hose is fine. Smaller stuff creates excessive pressure drop and larger stuff just makes it harder to drag around.
Rod
CNKS
03-12-2003 18:45:19
Cliff and Rod gave you excellent advice as they have many times on this board. Go with HVLP gravity feed. It is slower, but if you have not painted before, you won't know the difference and MUCH less overspray. I have not had the drip problem with mine, and you can paint the underneath stuff without going completely upside down. There also plastic inserts for upside down painting, haven't tried any yet. You can get a reconditioned Platinum from www.sharpe1.com for about $180 or about half price. You can get a new Sharpe Cobalt primer gun for about $120, I think from www.thetoolwarehouse.com. The touchup gun is an excellent idea. If you really want to learn to paint and don't intend to stop with your tractor, those 3 guns, or equivalent are what you need, at least to start with. The Cobalt needs a lot of air, though. Stay away from the cheap stuff, you will be glad you did. Don't know what the post below meant by not using enamel paint, if you use urethane, or hardened enamel, you need a supplied air system to prevent exposure to isocyanates.
Rod (NH)
03-12-2003 17:09:06
Hi Jeff,
Opinions follow :o).
Be cautious on the 3 cfm/hp "rule of thumb". If you are dealing with true hp it probably is reasonable, especially for older machines. However current hp ratings have been so botched by manufacturers that it may or may not be true. There are a number of 5 and 7-1/2 hp (so called) compressors out there that would not meet that rule of thumb. Take a look at your motor nameplate. It should have voltage and current ratings on it in addition to hp. A true 5 hp motor at 230 volts will draw about 21 or 22 amps at full load. If you are in that area, I would suspect you are close to the 3 cfm/hp rule. However, if your 5 hp motor is only 115 volt or draws only 15 amps if at 230, I doubt very much that you will achieve 3 cfm/hp...in fact you may be closer to 2 cfm/hp. In any event, I wouldn't get too hung up on the numbers at this point. If you were in a production situation it would be different.
I am personally not a fan of HVLP. Since I learned on "conventional" guns years ago, I find using an HVLP to be quite slow...I feel like I am painting in slow motion. Of course I am used to using a remote cup pressure feed arrangement that puts down a lot of paint in a hurry. Gravity vs. siphon...oh, I don't know. I don't like either since I prefer the remote cup. That gets the weight of the paint (considerable if you're talking a qt) out of my gun hand and is truly all-position. Upside down to get the bottom of stuff is a snap. However, the remote cup requires a pressure fed arrangement. I have both gravity and siphon in my two "touch-up" guns. Either will tend to drip paint if you get too far out of position. I hate it when that happens, especially if it drips on your fresh paint! I will say that the gravity one is easier to clean...but is also a real pain to set down temporarily without a damn "special" holder. Gravity fed has only come about with the advent of HVLP. Before that everything was either suction or pressure. I suspect that reduced operating pressures in the gun passages with HVLP has made it more difficult to properly suction paint to the tip, hence emphasis on gravity feed.
The 10 psi at the cap means that a maximum of 10 psig is present just under the air cap when the trigger is pulled. It is a legal requirement for HVLP. You will have no way to measure it without special test equipment. I wouldn't concern myself with this at all (unless you are in one of those California counties that require use of HVLP by law). Any HVLP gun should have stamped on the handle somewhere what pressure is to be used at the inlet to the gun to achieve 10 psig max at the cap. This is the number you need to be aware of with HVLP. For my HVLP "touch-up" gun this is 29 psig. I think that is pretty typical but it should be stated for each gun. A non-HVLP is likely to have inlet pressures up in the 40-60 psig area. You should always tee in a pressure gage at the point your hose connects to the gun (the inlet to the gun). You will need such a gage to set your operating pressure properly each time you use it. With the trigger wide open, adjust your wall regulator to get the proper inlet pressure at this gage...either the pressure stamped on an HVLP gun or the pressure specified on the material tech data sheet of your paint for conventional guns. Do NOT try to set it to any 10 psi. That is at an HVLP cap and can be substantially different (lower) that at the inlet on the same gun.
All reciprocating air compressors exhibit a drop in cfm capacity with increasing pressure. It is due to the changing volumetric efficiency as the discharge pressure goes up. Single stage compressors can show a significant drop at higher pressures. I once had an old single stage machine that provided 7.8 cfm @ 40psig and 6.3 cfm @ 90psig. That type of drop with higher pressure should be quite typical. Two stage machines will show a much smaller drop because the compression ratios per stage are significantly less than a single stage, yielding higher volumetric efficiency. If you wish to compare compressor capacity with gun capacity, you need to allow a liberal amount for pressure drop from your tank, through your wall regulator and then to your gun. My suggestion would be to use the compressor capacity at 90 or 100 psig...definitely not 40. If you are using say 30 psig at the gun inlet, you should figure on it being necessarily much higher back at the compressor, which is what your compressor is rated on.
Personally I would not recommend getting into expensive high-end materials and equipment at your stage. Professional body shops that do high-end paint jobs on a continuous basis use materials and equipment that could make the DIY go broke trying to duplicate. Unless you want to compete with that $5000 paint job on a Mercedes, my suggestion is that you do not try. Tractors do not have large flat surfaces and the sheetmetal is only a portion of the total. There are usually a lot of cast surfaces that you will never get to a mirror finish, realistically speaking...nor should you try. If you are considering doing your tractor piecemeal, you might consider only a touch-up gun. Matter of fact you should consider a touch-up gun anyway. There are so many small pieces on a tractor job that having only a regular size gun is unnecessary overkill.
The direction you take should also be guided by safety considerations. Unless you have (or are planning to get) fairly expensive supplied air respiratory equipment, you should stay away from urethanes and hardeners in enamels, including clears. That is, unless you wish to play fast and loose with your own health. That pretty much leaves the synthetic enamel that you mentioned and automotive acrylic enamel, both unhardened. That, in turn, negates any possible color sanding and buffing...you would destroy the gloss in the process. So forget any corrective action after the spraying is done. As woodtick said, practice and practice some more...on vertical sheetmetal. You need to develop the knack for putting the paint on without runs or excessive orange peel...a fine line...because you will have to live with the result with the unhardened enamels. It's not hard. It just takes a little practice.
I also would not be greatly concerned about your compressor capacity. Since you are not in a production situation you can make do with less air from the compressor than the gun needs on a continuous basis. The fact that your tank is 60 gallons gives you a reasonable reserve and will assist in prolonging the actual "trigger on" time. Certainly if you attack the matter piecemeal you should not have a problem with any reasonable regular size gun. I just don't think it's a problem you need to be too concerned with at this point. I would recommend for now that you get a $40 or $50 knock-off touch-up gun, some synthetic or acrylic enamel, use your existing compressor and practice. You can always move up to higher quality equipment later without much, if any, wasted costs. I did most of the sheetmetal piecemeal on my AC-B last summer with just a touch-up gun. It was simply too much of a bother to fire up the large gun for what really was several separate pieces, none of which had large unbroken surface areas. I wouldn't try it on the hood of a full size car, but that's a different situation altogether. For your trucks, and if your tractor has large unbroken areas, you would want a full size gun. Get whatever your budget can afford and don't get overly hung up on brand names. You can achieve quite respectable results without trying to compete with the high-enders in either materials or equipment.
Rod
John
03-22-2003 18:07:16
 Re: Re: Spray Guns....what does all of this mean??? in reply to Rod (NH), 03-12-2003 17:09:06
I agree with him completely as far as practice. Just a bit of advice though. You might want to stay away from painting the wifes car. She might not think that her new Explorer needs to be canary yellow with black doors as much as you think so. Do not ask how I know this. The best part about doing this is that if you screw it up all you have to do is sand it off, and you have already done this, so you are experienced. I just painted Desert Sunset (Case) for my first painting and am so impressed with myself. It can be done.
Cliff Neubauer
03-12-2003 16:05:58
You've already been following the best advice I could give you and that is to follow the disscussion at the autobodystore.com site. I think your compressor should be able to handle the Finishline II gun, especially when painting a tractor where you aren't spraying non stop. The cap pressure is the air pressure measured as it comes out of the air cap and the higher pressures are the pressures at the gun inlet, the pressure drops as it goes through the gun. The 10 psi at the air cap is what is used to classify HVLP guns, 10 psi and less is HVLP and over 10 psi is not. I've never used a Finishline gun but from what I have read it should be a good gun for you. If you ever start doing alot of painting and want something better you could use your Finishline as a primer gun.
Larry G
03-12-2003 14:48:22
Jeff, I only know enough to be dangerous but I have painted +/- 25 tractors in the last 5 years and learn a lot each time. As far as a gun I have used regular and HVLP and the HVLP is by far the nicest to use and much less overspray and less paint used. I have used both siphon and gravity feed HVLP and both work well. Personally, I prefer the gravity. Only difficult painting underneath. As near as I can tell your compressor is plenty big enough. My best hint is preparation, preparation, preparation. Use a good sandable primer especially if any light pitting. Sand carefully and then seal with a good epoxy primer such as the Omni line from PPG, then paint. Best of luck
woodtick
03-12-2003 06:53:51
Jeff, Painting has become a science over the last 20 years or so, But I can tell you that a e-inexpensive suction gun will do a nice job. stay away from enamel paint , study the paint systems with yor dealers, hang out at a body shop you will pick up tips. get a cheapy gun and practice,practice,practice
