Cleaning a sand blasted tractor
Dave
03-12-2003 01:15:36
How do you clean a tractor that has been sand-blasted down to bare metal???? I dont like to use soap and water and paint thinner is pretty expensive. what product can you use???
Thanks
CNKS
03-12-2003 18:25:38
 Re: cleaning a sand blasted tractor in reply to Dave, 03-12-2003 01:15:36
PPG makes wax and grease remover--DX 330, use this just before you paint to remove residual oil and fingerprints, etc. You CAN use soap and water, or a water based cleaner. Just dry it good and use a rust converter product such as Rass O' Nil (Picklex 20), (do a search I believe it is www.autobodystore.com.) to take care of the flash rust. Expensive, but a pint will do a whole tractor. Lasts for months if you keep water off it once you use it, and you don't have to paint right away. For light dust, once it is clean, blow it off as the other post says and use a tack rag.
Kevin
03-12-2003 03:26:11
Blow the hole thing off with air yhis will get rid of the dust
