Rusty Jones
11-25-2001 17:21:36
Re: Re: Re: Re: Any suggestions on compressor sizes? in reply to Slappy, 11-18-2001 07:03:03
When buying an air compressor, look for the CFM, which means cubic feet per minute. Any air compressor will pump up 100 lbs., but the CFM is most important. The info you got from the other correspondents is good. Also, think about getting the vertical type, as you can stick it in the corner of the garage and it'll be out of the way. I bought an Emglo compressor, and it has given me very good usage, for painting, sanding with air tools, and sand blasting. Note: When sand blasting, stay far away from the compressor air intake, as it will suck in sand if you're not careful, thusly ruining the rings, etc. My compressor will keep up to air tools and for painting, altho it runs continuously for air tools, but catches up quickly. When you are ready, go to a store that specializes in auto paint and supplies, and buy what they recommend. Sears sells light duty compressors, but I don't think they'll stand up to hard usage over the years! Remember, don't go for air pressure, go for top CFM! Yours: Rusty Jones p.s.: be prepared to pay around $900 to $1500 for new, altho you may be able to find a good used one for less. look for garages and body shops having a "going out of business sale", but don't buy one that looks neglected!
