Pulging bolt holes befor painting?
Frank Brunke
03-16-2003 15:27:04
I have an old ('69) MTD garden tractor that I am rebuilding. I have it apart down to the frame. There are a lot of welded nuts on the frame and I am wondering if it would be a good idea to run a bolt into the nuts before painting to keep the threads clean. Should I remove the bolts right after painting? before the paint hardens?
Also, I have access to stainless steel hardware, and was wondering what the cons would be to replaceing the standard bolts with stainless? thanks
Frank
CNKS
03-16-2003 17:37:59
 Re: pulging bolt holes befor painting? in reply to Frank Brunke, 03-16-2003 15:27:04
Not a bad idea to plug them. Amazing how a little paint makes bolts harder to insert. But, I would be more concerned if you were painting a shaft that fits fairly tightly in some other piece. you can remove the bolts whenever you want, as a little exterior paint will have negligible effect on removal.
Don LC
03-25-2003 06:05:27
 Re: Re: pulging bolt holes befor painting? in reply to CNKS, 03-16-2003 17:37:59
The bolts will cause more trouble than it's worth....
