Paint for wood's mower
Mark
03-24-2003 14:00:17
Does anyone know where i can find the tan/brownish paint that is on Wood's belly mowers? I also need the decals. Thanks in advance.
Mark
OC JOE
04-04-2003 07:30:40
 Re: paint for wood's mower in reply to Mark, 03-24-2003 14:00:17
Mark,
I painted my Woods mower with Rust-oleum almond
color,it was almost a perfect match.The prep before the top coat is the main thing, to get a job that will last,sandblast or grind the rust,
use a metal prep,use epoxy primer,then topcoat.
Joe
Kevin
03-25-2003 03:48:23
Most implement dealers can get that color but if it were me I would go to a paint store and get industrial primmer and paint such as Corlar 525 primer and Imron 333 for the top coat.This will give the best corosion resitance that you could get.Hamiltons Protective Coatings in Decatur IL.can get you what you need.
sammy the RED
03-24-2003 18:17:59
Try a Woods dealer.
