Primer, etch or regular
Don c
04-01-2003 04:02:17
Whats the difference and when should you use each, using on JD with JD paint, 1952 JD.
thanks Don c
Jerry B
04-01-2003 07:43:52
 Re: primer, etch or regular in reply to Don c, 04-01-2003 04:02:17
The self etching primer is designed to be sprayed over bare metal or body filler. The primary purpose is to etch the surface of the metal slightly with the acid in the primer. This procedure disolves any remaining surface rust on the metal and provides a "clean" surface for the primer-filler to stick to.
