Advice
Charles Park
04-09-2003 14:26:20
I have a small pancake compressor. About a 3hp. Question is can I use it to power a paint gun. I would like to know about makes of spray guns to consider. Also, filtration systems to remove water and particles from the paint stream.
Truck
04-10-2003 19:42:35
 Re: Advice in reply to Charles Park, 04-09-2003 14:26:20
It might be sufficient for small parts painting with a touch up gun. Most likely you will run out of air if you are trying to paint an entire tractor at once.
Filter regulator units and water traps are very simple items. Brand will not matter a whole lot. If you are not going to be doing the painting very often, even the cheap imported ones wil suffice.
Truck
