HLVP Turbine Sprayer from Tip Tools
kman
04-19-2003 03:57:28
Thinking seriously about buying a HVLP turbine system from Tip Tools ($599). Anyone have any experience with these? I like the idea of the self contained system. They also have a choice of pressure fed or gravity fed gun. Thinking of going gravity-sounds like less paint is wasted in cup. I am just a beginner and have a couple of tractors I want to paint and thought this might be the way to go since my compressor is old and small. For any big sanding jobs I can use my bothers compressor and make a mess at his shop! Any comments appreciated!
CNKS
04-19-2003 09:22:39
 Re: HLVP Turbine Sprayer from Tip Tools in reply to kman, 04-19-2003 03:57:28
This is only my opinion -- Nothing wrong with the unit, but the only advantage over a conventional system is it is portable. After you paint your 2 tractors, you will have a system that gets little use, unless it inspires you to do more. A good air compressor has many more uses, and is unlikely to sit around and collect dust. HOWEVER, as far as cost goes, I have far more than $599 invested in my compressor and paint guns.
Barry Maxwell
04-19-2003 04:28:47
I have had a HVLP 90 system from TiP Tools for about four years now and am very satisfied. I also was a beginner when I bought the system and have developed into a fair painter with good results. I do not have the gravity gun, but I understand both guns have exactly the same mechanism. Good luck.
