Hi Mike, My own suggestions follow: 1. Bang out the dings and dents carefully from the backside using a ball-peen hammer. A general purpose dolly helps some here on curved surfaces. Try to get everything to within about 1/8" of where it should be without any high spots exceeding the expected final surface. Peabody's post about the tube of sand seems like an excellent idea...I'll have to try that out. 2. Clean and degrease all surfaces with a specialized cleaner such as PPG's DX 330 wax and grease remover or similar. Scuff sand all sound paint that is to remain, if any, with 220 grit paper. 3. Sandblast rusty areas if possible. If not, use a power wire brush and/or sander with 80 grit to remove as much rust as possible, if any. If any rust remains, especially in the bottoms of pits, use a rust treatment such as Permatex Extend or equivalent. I have found it easier with such a product to use a foam roller rather than a brush. It's difficult to avoid brush stokes with this stuff. If you have only light flash rusting, a phosphoric acid treatment would be advisable in lieu of this method...but that's another case. 4. Do another wipe with the DX330 (or similar) and prime with a 2-part epoxy primer such as PPG OMNI MP 170 or equal. Be sure to observe the required time windows with this type of product. 5. Use a polyester plastic filler such as those by Evercoat or something similar to fill in the low spots (not the rust pits). I happen to prefer the smooth variety without the fiberglass strands. Level with 80 grit sandpaper. You may need several applications to get smooth. Use a long flat board as a backer towards the end here to assist in making it smooth. 6. For the rust pits, it depends on their depth. If over, say 0.005", I would use a flowable polyester finishing putty such as that from 3M or equal. This is simply a runnier version of the plastic filler above. If the pits are not deep, say less than about 0.005", I would use a lacquer type putty such as this from 3M. Use a rubber squeege here and give the lacquer stuff PLENTY of time to fully dry. 7. Sand everything with about 220 grit paper...by hand or light power with an orbital sander if you have one. 8. Do another wipe with the DX330 and give everything a final overall coat or two of the same epoxy primer as above. 9. Beyond this point the products to use (including hardeners) would depend on respiratory safety matters (and cost). Do a search in this forum on "isocyanates" for previous discussions on this important issue. Rod
