DuPont paint code for Oliver tractors?
Luke
04-21-2003 12:28:06
Hello,
The Oliver 1750 I have been working on for a friend is getting closer to being painted every day. He decided that he would like to go with DuPont paint now but we don't know how to match the paint with the tractor. Is there a paint code or does anyone know what it would be for clover white, Oliver green, and silver for DuPont? Also, if there is, what hardener and thinner is recommended to use for this brand? Thanks
Farmer in the Dells (WI)
04-21-2003 18:40:02
 Re: DuPont paint code for Oliver tractors? in reply to Luke, 04-21-2003 12:28:06
Luke, the info I have is Oliver Green Dupont # 019 or 030. Make sure you look at a chip before you have it mixed. I suspect you'll spend $40 + per qt to have it done in Dupont. I do not have a Dupont code number for Clover White. The number for Martin Senour is 90G-3822 or Ditzler 8229. I am looking at a can of AGCO Clover White I picked up at my dealer. It is enamel Clover White 79014806 and was $14.90/qt. I am planning to use synthetic reducer from NAPA callled Synthol. It is a bit expen$ive @ $25/gal but it is what the dealer suggests I use. NAPA suggested two different hardners. 1 @ $12/pt and the other is the synthol match @ $33/pt. Since I am not doing a showpiece this time, I'll probably opt for the economy hardner. The reducer will be used at about 1:4 parts paint so the gallon will go a long way. I will also pick up some cheaper reducer for cleaning the gun which by the way, am told will need to be about 40# at the gun for a suction type gun. I have not broken down to buy a gravity feed gun yet but that is more critical if you are shooting metalics. Earlier posts I have read indicate that painting is about 90% prep and 10% application and I agree. Watch your pressure, humidity, air temps and don't skimp on the primer. I am using a rust inhibitive primer and praying it is compatable with the AGCO paint. Hope that helps
Bill Hires
04-21-2003 15:40:09
The best source for information is, Lyle Dumont, Sigourney, Iowa, Phone # 515-622-2592
Bill Hires
04-22-2003 04:53:25
 Re: Re: DuPont paint code for Oliver tractors? in reply to Bill Hires, 04-21-2003 15:40:09
I failed to give you the DuPont code for white, it is, # 59664, similar to PPG 8229. DuPont lists eight Oliver green codes, this is the reason I gave you person's phone number to contact.
