Nason FastDry
kman
04-27-2003 04:53:41
Wondered if anyone has use this cheaper brand from Dupont? I was thinking of using it on the cast part of my tractor. I don't want to use hardener because of the danger from fumes.
Jerry B
05-06-2003 06:09:42
 Re: Nason FastDry in reply to kman, 04-27-2003 04:53:41
JIm tells it right.
Buy a good respirator while you are shopping for your paint and supplies.
Jim Slade
05-05-2003 17:29:05
Nason is not to bad, but it will not cure if there is no hardner. what I have done is only use a capfull, approx. a teaspoonfull. for every quart of paint, this reduces the toxicity a great deal and it will setup and harden after a longer period of time. but you still need a good filter mask if you're going to spray it. The hardner in most two stage paints is what makes it a problem to work with. eg. your health. Take precations and live longer.
Jim Slade
05-05-2003 17:28:58
Jim Slade
05-05-2003 17:28:49
