Synthetic paint and clearcoat
carl
04-27-2003 06:49:36
A restoer I know claims his painter uses cheap enamel from TSC and topcoats with clear while the enamel is wet.What type of clear should I use? They turn out beautiful and seems to last,any negative feedback?
sammy the RED
04-27-2003 19:25:48
 Re: synthetic paint and clearcoat in reply to carl , 04-27-2003 06:49:36
My advise is to use anything BUT the TSC paint.
Jim Slade
05-05-2003 17:20:40
 Re: Re: synthetic paint and clearcoat in reply to sammy the RED, 04-27-2003 19:25:48
synthetic paint and most clears will not stick after a few years.and you will have problems if you have to repair and blend the paint they are incompatible.if you want a clear coat go with a true urethane and then topcoat with clear.
