Omni MAE acrylic enamel over alkyd primer ?
RJ
04-28-2003 17:18:22
I bought a tractor that has been almost completely primed with red oxide alkyd type primer. Personally I like this primer because of the way it adheres to just about anything.
I wanted to paint the tractor with Omni MAE acrylic enamel and will be using no hardener because of the health risks. Will I have any adhesion problems with the acrylic enamel over this type of primer?? Or should I go over it all with an acrylic type primer-sealer? I did a little test spot and the Omni adhered excellent to the red primer, but concerned about long term effects?? Thanks in advance for some feedback on this.
NCJohn
05-04-2003 07:33:22
 Re: Omni MAE acrylic enamel over alkyd primer ? in reply to RJ, 04-28-2003 17:18:22
I am no expert, but thought I would comment. I would be encouraged by the fact that the primer did not blister or peel when you tested it. But, if it were me, I would probably seal it with a product recommended by the paint experts at your local auto paint store. When I have used the modern paints or primers over top of the old synthetic (alkyd) enamels, it almost always blisters right away.
RJ
05-04-2003 17:49:32
 Re: Re: Omni MAE acrylic enamel over alkyd primer ? in reply to NCJohn, 05-04-2003 07:33:22
Thanks for that info, as you said I think I better not chance it. I am going to see what Omni sealers might be available. Seal it then apply the Omni and I should be good to go.
