Epoxy primer to seal off alkyd primer? Will it be ok?
RJ
05-05-2003 12:03:22
My tractor has been completley primed with red oxide alkyd primer. I would like to lay down acrylic enamel paint, so to be sure I will not have paint adhesion problems, blistering, paint bleed, problems, ect. I was considering using Omni MP-170 epoxy primer. Will this primer adhere to the alkyd primer and seal it off? What prepping will need to be done to the alkyd primer before I apply the epoxy? I assume some light sanding and then cleaning? Thanks in advance for some feedback on this.
Jerry B
05-06-2003 05:50:54
 Re: Epoxy primer to seal off alkyd primer? Will it be ok? in reply to RJ, 05-05-2003 12:03:22
You can use E-prime over acrylic laquer with no ill effects. But I have to ask why would you want to? Acrylic enamel will work just fine over the laquer primer and will not lift it.
If I truly wanted to use E-primer over laquer primer, I would sand the laquer first with 240 grit and then mix the paint have it in the gun, ready to spray.
Mix your e-prime using a little drying retarder to slow the drying process. You might add a touch of mid-coat adhesion promoter just to be on the safe side in case some areas of laquer primer did not get sanded well.
Give your tractor a light coat of e-prime covering everything well with one medium coat. Set the primer gun down and grab the paint gun and shoot your first coat of paint. While the first coat tacks up you can clean your primer gun. By the time you are done cleaning, the first coat of paint should be tacky enough to finish the paint job.
Using e-prime as a sealer is an old trick, as e-primer will not react with any underlaments or top coats. Works the same as a regular primer-sealer.
RJ
05-09-2003 18:44:36
 Re: Re: Epoxy primer to seal off alkyd primer? Will it be ok? in reply to Jerry B, 05-06-2003 05:50:54
Thanks Jerry for the informative feedback.
