What Primer Should I Use?
Bill VanHooser
11-25-2001 06:32:26
I removed rust and old paint on various small parts on my Farmall Cub. The parts were removed for repair and need a prime coat of paint, but I do not plant to finish coat them until spring. The tractor and parts will remain in the garage this winter. Under these conditions should I use epoxy, laquer or urethane for a primer? Should I prime again before applying a top coat in the spring? Thanks for any recommendations you can provide..... .Bill
