Paint for Implements
Craig
05-12-2003 04:18:20
I have several implements I would like to paint. Can someone recommend a good paint that is easily applied and can be sprayed over rust? I am not looking for show pieces, I just want to clean up my equipment without having to sandblast or wirewheel everything.
Thanks!
Craig
Bill
05-15-2003 12:19:25
 Re: Paint for Implements in reply to Craig, 05-12-2003 04:18:20
POR 15 is the paint for you. Wire brush the steel to get off lose material and paint over the rust. will not stick to oil or hydralic fluid so you do need to wash the surface. Use a brush to paint and it covers good and bonds to rust.
sammy the RED
05-13-2003 17:35:20
If you dont clean them up first, the paint will make them look worse than what they are now, when it starts to flake and peel off.
Leave them like they are.
