Primer useage
Jake S
06-03-2003 11:56:18
Im working on my sheet metal now and the tractor later in the year,because im still using it. Some of my sheet metal is good and some area has rust or pits.If i sand down this area what kind of primer i should use.I dont plan on striping all of the sheet metal
or do you think i should,the paint is holding up good in spots.Should i use a good grade of primer or the etching primer first? What should i do about the pits?
