PAINT TO SOFT
DAVE S.
06-08-2003 06:16:09
I painted my dump body about a year ago with sherwin williams acrylic enamel.I did everything acordingly and it looks great but the paint chips to easily.I had this happen before with this brand some years ago and I thought maybe I made some error at the time.I was dissapointed to have it happen again.I've had good luck with dupont paint in the past but it was only available in basecoat and I never clear coated before.Can I now use clear over top for a tougher finish?
Don(CO)
07-16-2003 18:22:00
 Re: PAINT TO SOFT in reply to DAVE S., 06-08-2003 06:16:09
If you are using acrylic enamel, you should use an isocyanate hardener designed specifically for acrylic enamel on your final coat. I believe most acrylic enamels use an 8:6:1 ratio. 8 parts color to 6 parts lacquer thinner to 1 part hardener.
