Painting over primer
Ted
06-08-2003 18:14:50
I have primed parts anywhere from 6 months to a year ago and was wondering if I needed to scuff the primer befor painting? Also how much time should I allow befor painting over primer with the base coat and what would be the maximum amount of time can I let the primer set befor I have to scuff it befor applying the base coat? I am using Dupont 615 S Vari Prime With Dupont Centari Acrylic Enamal.
CNKS
06-10-2003 19:23:13
 Re: Painting over primer in reply to Ted, 06-08-2003 18:14:50
Go to DuPont's web site and look up your paint. It will tell you if there is a window during which the primer must be topcoated. Also remember that primer does not prevent rust, particularly if it gets wet, so that could be a problem if you wait too long.
Ted
06-10-2003 17:14:44
I had about a year pass between primer and painting. All I did was go over it lightly with a scotch bright pad then wiped it down to remove the dust.Turned out just fine...
