David Bradley Green .... Bill???
Adam P
06-11-2003 20:42:11
Howdy, got (to me) a slight tricky one. I need a Martin Senour paint code for David Bradley Green. DB green, (the color) has always been discribed as a 50/50 mix of JD green and JD yellow. I am wondering,,, is there a way to "correctly" figure out the right color code based on that info??? Then x-referance it to NAPA paint (acrylic enamal)
Thanks in advance
AP
PS Bill, if your looking, I did see a post you made on this regarding DuPont...But was kind of curious to revisit due to the NAPA M/S and as to whether, you can "add" two differant codes and wind up with an answer.....yikes and thanks
Bill Hires
06-12-2003 04:49:08
 Re: David Bradley Green .... Bill??? in reply to Adam P, 06-11-2003 20:42:11
If you can come up with a chip of the original paint your paint dealer should be able to match it. Some paint suppliers will mix small quanities for checking on the correct match. David Bradley DuPont Signal Green code is 43073 (Ditzler code 41780) Red code is N1488 H, or F1212 (lite) (Ditzler code 72155) You might come up with a color code sheet at a DuPont dealer and have your Martin Senour dealer read off of that. Good luck!
