Second Coat
Randy McC
06-16-2003 16:19:01
Six days ago I applied a coat of Nason paint on my tractor rims using a catalyst and reducer. The finish is OK but I could use another coat.
What preparation do I need for the second coat? I am painting outside.
Keith
06-16-2003 19:21:48
 Re: Second Coat in reply to Randy McC, 06-16-2003 16:19:01
Just my 2 cents and experience, use green 3M Pot and Pan Scratcher,"Gently" rough up new paint and spray.
CNKS
06-16-2003 18:32:13
I would sand lightly with 400 grit. Will work better wet, but don't sand through your primer, hose it off, dry, treat with wax and grease remover and give them a couple of more coats. Your paint is essentially cured and I have had no experience recoating without sanding after that long -- next day, maybe.
