Best way of getting overspray off ur tires
andrew
06-23-2003 07:36:54
hi does anyone now the best way to get paint off ur tires
fred kobs
07-02-2003 13:27:52
 Re: best way of getting overspray off ur tires in reply to andrew, 06-23-2003 07:36:54
I use a rag soaked w/laquer thinner. Just be careful not to let it touch the fresh paint. just my 1/2 cents worth.
Peabody
07-01-2003 11:10:06
Go to the "Articles" section to the left under "Research & Info." The next-to-the last item is an article on tire paint. I tried this Miller tire paint and it really works well. You can buy a quart for $12.50. You only need a couple of ounces to do front & rear tires. Good stuff!!
Trevor
06-25-2003 13:40:36
Best and easiest way to get over spray off tires is brake fluid. Just use a little on a rag and rub the overspray right off. Plus a nice side affect is that it makes the tires shiney and black. (until dust sticks to it)
Be careful not to get any on your good painted surfaces cause it will come off too.
Bill Hires
06-23-2003 15:08:57
I have used a product called "Goof Off". You can buy it at most stores selling house paints, it is used for removing dried latex paints. I apply it with a rag and wipe it off with 3-M pads, or steel wool. Use a thin, wide putty knife to protect the rims as you apply it. Apply a good spray on tire cleaner after you get through removing the paint.
