What would you recommend
jdk
06-23-2003 12:58:12
What would you recommend? Yesterday I painted my tractor using John Deere Classic Green and hardner, but unfortuneately I pickup up some dirt in the process. Overall the finshed product looks great except for two seperate areas (air cleaner & front pedestal). Does the paint need to set up a few days before respraying, or can it just be resanded and sprayed? Secondly, how long must the paint cure before installing the decals? All help would be appreciated!
CNKS
06-23-2003 19:12:38
 Re: What would you recommend in reply to jdk, 06-23-2003 12:58:12
If you used hardener, maybe even the same day for sanding and repaint. You can easily tell once you start sanding. You will probably want to wet sand. Decals should not be a problem either.
Richard
06-23-2003 17:22:41
On the first question, depends on the drying conditions. At higher than 70 degree days without heat, I'd give it 4 days. Your decal supplier should provide the cure time, as I use Jorde's and he recommends up to two weeks.
