JD LA Antifreeze on Spark Plug
LH
08-03-2003 21:46:50
I am scared to ask this question; I pulled my plugs to check them because I had a hard time starting the LA and one plug had antifreeze on it from inside the cylinder. Also, I loosed one manifold bolt on the side next to that cylinder and antifreeze leeked out. What does this mean? What are my options? Thanks for any input and help on this lovely little machine!
LH
Trevor
08-05-2003 09:59:02
 Re: JD LA Antifreeze on Spark Plug in reply to LH, 08-03-2003 21:46:50
You should post this question on the John Deere board. This board is for Painting & Body Work questions only.
landes
08-05-2003 10:49:04
 Re: Re: JD LA Antifreeze on Spark Plug in reply to Trevor, 08-05-2003 09:59:02
Thanks Trevor for the heads up. I clicked on the main board so I can't understand why it posted to the Body/Paint board. Anyway, I will possibly try again.
