Electrolysis again
Curt K.
11-29-2001 17:14:21
I have a 15" x 30" cage made from 1/2" rebar with about 2" spacing on the bars. When I attach the battery charger it pegs the meter then trips the overload circuit on the charger shutting it off. This occurs on all but the lowest setting 6v @ 2amp. with this setting it sits with the needle almost pegged but does not shut down. How can I get more power to the solution. Or what else is wrong.
terry
11-30-2001 18:38:08
 Re: electrolysis again in reply to Curt K., 11-29-2001 17:14:21
i hope your not clipping both leads to the "cage "somehow or another your geting a short between your part and the cage i have just started working with electrolysis my self but have the support of my work places corosive engineer i am useing a fifty five gallon plastic drum with four anodes , "rebar" been geting some good results so far
Red Dave
11-30-2001 08:18:11
Do you have the solution in a non-conductive vat or tub?
Is the anode touching the part you are trying to clean?
Does the battery charger work normally otherwise?
Just a few thoughts
Franz
11-29-2001 21:08:56
Something is shorting out
TractorNut
11-30-2001 20:31:51
 Re: Re: electrolysis again in reply to Franz, 11-29-2001 21:08:56
I tried the electrolysis today. I could only find Arm and Hammer Washing detergent(for laundry). It does not say washing soda. The process does not seem to be working very good or at all. Am I using the wrong stuff in the water. If so, where do you find washing soda. I have been looking for it in large supermarkets.
Franz
12-01-2001 14:53:16
 Re: Re: Re: electrolysis again in reply to TractorNut, 11-30-2001 20:31:51
You got the wrong stuff, See my ARM & Hammer posting above. Give that stuff to the wife for doing laundry.
Seems to be available in supermarkets here, Box is about 8x6x2" yellow with blue letters.
You may be having the same problem I had finding it, supermarkets are set up to be used by women.
terry t
12-16-2001 05:39:41
 Re: Re: Re: Re: electrolysis again in reply to Franz, 12-01-2001 14:53:16
Here in Tenn. our local co-op carries "soda ash" some tobacco farmers burn it under their tobacco to get a darker finish. This is PURE sodium carbonate. This is what your lookin for in the washing soda. This stuff really works wonders. I have been using it for the last few weeks to clean parts for my SuperA. I pitch the parts in the solution at night and come back the next evening and take them out.I only have a 6 amp battery charger. I have found that if you take and scrub the parts with "brillo" pads after soaking, it really shines the parts up for painting. PS the soda ash is about 12.00 for a fifty pound bag. Enough to do bunches of parts!
