clear coat - rough texture
ChrisL
08-11-2003 19:53:32
OK guys before I started painting anything important (my machinery & tractors) I figured I better get the wife's car all one color from the deer incident - have an HVLP setup from Harbor Freight - seems OK -- it doesn't use much material - (which might be part of the problem) but it does an OK job - my problem is this - I don't think I was getting material out fast enough and so it was drying faster than I was spraying - so my clear coat, instead of being smooth and clear and shiny has a look of being just hit by a real fine water mist - a rather interesting texture - kinda nice for machinery but not so great for the car - so should I wet sand with some real fine sandpaper or what?
I used about the right amounts of paint and clearcoat (nason) for the job, but I am stumped and looking for options.....
not a real body guy by any means -
i tried a little turtle wax polishing compound by hand and it didn't seem to phase it.....
Jerry B
08-12-2003 06:43:09
 Re: clear coat - rough texture in reply to ChrisL, 08-11-2003 19:53:32
Sounds like you "dry sprayed" it. Some folks think that HVLP is the best thing since sliced bread. I have yet to find one that can keep up with a good gravity fed Devilbiss. but anyway...
You will need to sand the clear down to a smooth surface. Most likely you will cut into the base coat and therefore you might as well count on a repaint of the entire car.
Use 240 grit on your DA sander to smooth out the surface and remove most if not all of the clear. I would then follow up with with a good sanding using 320-360 grit. Be sure to sand around edges well but try to avoid cutting through to bare metal. The best way to avoid this is to sand by hand using a good quality sanding block.
Now you can spray one more coat of paint and then the clear.
scott
09-05-2003 19:27:30
 Re: Re: clear coat - rough texture in reply to Jerry B, 08-12-2003 06:43:09
this jerry guy must work for somebody that sells materials you didnt dry spray it you just didnt reduce it enough try 800 on a da and then buff it start with a (white) waffle pad and compound and then go to a (gray)smoother waffle pad and polish it be careful sanding around any bodylines or handles mirrors trim etc. as for the gun the hvlps are awesome i have painted completes with a quart of base but the harbor freight deal leaves a little to be desired if you are going to do much painting get a SATA you will be glad you did hope this helps
