Painting Prep
Sam MI
08-12-2003 05:23:09
I have several items that need painting. These parts have a factory prime of some sort which is black. I want to use epoxy primer and my question is; this factory prime does not wash off with laquer thinner, so can is just scuff and prime over with epoxy or can I just finish paint over the factory prime? Thanks
Jerry B
08-13-2003 06:06:30
 Re: Painting Prep in reply to Sam MI, 08-12-2003 05:23:09
The black primer you are talking about is a factory applied epoxy primer. It will not dissolve under laquer thinner.
Sand this primer well with 220 paper and apply one good coat of 2K primer. Now you can either apply paint directly over the 2K as it dries or you can let it cure for about an hour or so and then block out your primer with 240 grit paper and then paint.
Either way will work just fine.
