Super greasy Oliver
Stu
08-28-2003 09:08:01
third party image
I am going to get into the painting of the Oliver. Its my first attaempt at any body work or restoration. I have all mechanical issues and leaks fixed, which is a really nice feeling. There is some serious thick gunk on the top of the tranny and on the 3ph arms etc. The oil seals in the cross shaft of the 3ph have leaked likely for 20 years.
What kind of process do you guys do to prep you tractors. I am looking for clean but I am not super anal about perfect clean one might say. I want to do a bunch of tractors at once to show other oil leaks I need to fix on the deeres, so I wonder what you guys think about the steam cleaning units that can be rented. Is that a good way? I have a small sand blaster, but I dont want to get sand into everything if there is another way, (other than scraping!!!!)
Photo attached.
Cliff
08-29-2003 22:28:20
 Re: Super greasy Oliver in reply to Stu, 08-28-2003 09:08:01
I bet if you hit it in about 3 stages. One time with oven cleaner. BTW I get it at General Dollar store. I buy about 6 at a time. Then use your pressure washer with water to rinse it down.
Then use some grease cleaner (aka motor cleaner) sold at the auto parts store . Rinse it again.
Then use oven cleaner again.
If you really want to get radical use aircraft paint striper from Auto Zone. However keep it away from rubber seals and don’t let it drift and get on the hood of your pickup. Trust me, I know!!
I have better results using the oven cleaner by using it in direct sunlight on a hot day. Spray it one fairly liberal, and let it work for 15 to 30 minutes. Then power wash all of it off! BE sure to wash it down real good.
CNKS
08-28-2003 19:32:37
I have never used a steam cleaner or a large sandblaster, wish I had both. I use a combination of methods, none of which works on all parts of the tractor, oven cleaner + pressure washing, chemical paint stripper, wire brushes on angle grinder and drill; needle scaler and spot blaster for hard to get to places. I remove ALL the grease and paint. It has to be, as you say "super anal clean" or your paint won't stick. If you don't want to remove all the paint, sand it good and use an epoxy primer over the whole tractor. I prefer to remove all the paint -- but then I have a lot of time. But be sure to get it squeaky clean.
Trevor
08-28-2003 11:16:23
If you just want to dry them up and get them kind of clean then just buy some varsol and go at them with a brush and a rag. If you want to get them cleaned to paint then you can try the oven cleaner trick. But beware the oven cleaner will remove some paint as well and you need a way to rinse it off.
You will still likely need to do some scaping but with a solvent it should be less.
