Forming a rim or lip around a hole
Dan
09-01-2003 19:59:43
How do you form a rim around a hole in a hood like those around a gas cap or muffler.
Jerry B
09-02-2003 07:39:32
 Re: Forming a rim or lip around a hole in reply to Dan, 09-01-2003 19:59:43
Determine the exact center of the hole
Determine the exact diameter you need.
Obtain and piece of conduit with outside diameter the size of the hole you want.
Cut, drill or saw the hole through the hood/sheet metal the diamter of the conduit.
Slide the conduit through the hole leaving the amount above the hood/sheet metal you want.
Weld in place.
Trim off excess from under hood/sheet metal.
Grind weld smooth.
Fill area with high quality body filler and sand to shape.
