Dupont Emron Paint
Jesse Imler
12-03-2001 18:38:31
Does anyone have any imformation on Dupont Emron Paint. Considering using on Farmall M. Any help will be much appriciated.
Thanks,
Jess
Kevin M. VanZanten
07-25-2003 19:28:34
 Re: Dupont Emron Paint in reply to Jesse Imler, 12-03-2001 18:38:31
I've just begun a boat restoration company out of midwest Michigan and I want to expand services including Emron refinishing and Awlgrip refinishing. I'm interested in training cources available for your product.
charles ethridge
12-15-2001 18:06:01
jess, i do not know if you are talking about imrom paint, if so i have painted several airplanes with this, goes on easy, looks wet all the time,BUT! you can not touch up or respray a small spot if it gets scratched or messed up, you have to repaint the whole part, i do not think this paint will have the wearing strenght for a tractor that will be worked or worked on. charles
Jerry B
12-04-2001 06:30:19
Imron is a true urethane paint. Sprays nicely and covers well. Requires a special clear should you be in the mood to clear coat it. Kinda expensive to set up the first time but once you have all the "extras" it could become your favorite paint to shoot.
I have shot a few gallons but I prefer to shoot Chroma One or even Nason urethane.
Cliff Neubauer
12-04-2001 09:53:59
 Re: Re: Dupont Emron Paint in reply to Jerry B, 12-04-2001 06:30:19
Isn't Imron a polyurethane paint? Regardless it is one of the most durable and lasting paints you can buy along with being one of the most toxic to use. Don't even think about spraying it without a postive pressure fresh air mask and a good paint suit.
mark
12-04-2001 17:57:58
 Re: Re: Re: Dupont Emron Paint in reply to Cliff Neubauer, 12-04-2001 09:53:59
dupont acrylic enamle works good with lots of hardener
RB/CT
12-29-2001 12:44:09
 Re: Re: Re: Re: Dupont Emron Paint in reply to mark, 12-04-2001 17:57:58
Extremely deadly paint without a respirator. The cancer causer and killer is the Polyisocyanates. I lost a friend to a brain tumor. The money you save without a spray booth and respirator are not worth it. Thanks.
