David Bradley Paint Codes?
Mic
09-20-2003 18:18:54
I have a Sears & Roebuck running gear under an old taperbox grain wagon. I understand that these were built by David Bradley, and used their paint scheme. I have seen David Bradley equipment with what I would call a lime green, but mine appears to be a fairly dark green, along with the characteristic David Bradley red. I have the DuPont green code as 43073. Before I have it mixed, does anyone know if this is the light green color? If so, was there a code for this darker green? Thank you.
JD-Iowa
04-08-2004 18:39:14
 Re: David Bradley Paint Codes? in reply to Mic, 09-20-2003 18:18:54
I have the same gear under a hay wagon, although mine seems to be reverse painted from what I have heard others talk about. I have (what is left of the paint) a red frame with green wheels and what is left of darker red letters spelling David Bradley in the back cross member. The ID tag says Sears Roebuck model 7001004 with serial # 5250136. It needs paint bad and I would like to get it right. So I would also like the paint numbers for the Sears version of this unit. A side note, Sears usually spec'd there own paint schemes on things, so these may not be the same as the regular David Bradley. I will be at a sears store this weekend so hopefully they can give me some info. and I will share that with yoe all.
Glenn in PA
10-20-2003 09:21:59
I have the same type gear and posted on the Garden Tractor forum. Was told to use IH Red and Deutz Green. Good luck.
