Anyone hear of Japan Dry???
BigBob
09-22-2003 08:26:57
Supposed to be used instead of hardener. Label doesn't have isocyanites on it. Is it worth trying?
Cgram
10-08-2003 09:57:48
 Re: Anyone hear of Japan Dry??? in reply to BigBob, 09-22-2003 08:26:57
I'v seen it mentioned on woodworking forums.
You might try posting the question in the forums at www.woodcentral.com and/or www.homesteadfinishing.com. Good luck
Try Canada Dry Instead
09-25-2003 03:50:40
If it's mixed drinks you're after you can do no better than Canada Dry.
CNKS
09-22-2003 17:47:49
I have not heard of it. The label may not mention isocyanates. For this you have to read the MSDS. However, if it is a legitimate product and indeed does not have iso's, the label should read something like: use an appropriate air purifying respirator, or a positive pressure (supplied air) system. If it does contain isos, it should read positive pressure, and not mention the air purifying (twin cartridge) respirator. I did not know this until it was mentioned by Rod(NH), so I give him credit.
CNKS
09-22-2003 18:17:08
 Re: Re: Anyone hear of Japan Dry??? in reply to CNKS, 09-22-2003 17:47:49
After doing a Google search, it appears that this product has been around a long time. Used mostly to speed drying of wood paints. I also found a Model T site where it was mentioned. I don't think it is meant to be used with modern paints -- Where did you read about or see it? You are right about it being iso free, but I doubt if it is compatible with modern automotive paint, I don't know.
BigBob
09-22-2003 20:14:19
 Re: Re: Re: Anyone hear of Japan Dry??? in reply to CNKS, 09-22-2003 18:17:08
I ran across it at ACE Hardware. The can says for enamel paint. It doesn't specify wood or metal.
CNKS
09-23-2003 06:48:46
 Re: Re: Re: Re: Anyone hear of Japan Dry??? in reply to BigBob, 09-22-2003 20:14:19
I doubt seriously if it is designed for automotive paint -- I'll see if I can find it next time I'm in our ACE store.
