Pitted areas in sheet metal.
AWB
09-28-2003 07:21:08
I have a tractor hood and grille that are badly pitted in spots. What is the best fix for this? I have tried some high build type primers with mixed results. Bondo?? Thanks, AWB
rustyfarmall
09-28-2003 07:44:34
 Re: Pitted areas in sheet metal. in reply to AWB, 09-28-2003 07:21:08
I have used bondo with good results, but I am not an expert, still learning.
Gene Bordelon
09-28-2003 08:04:20
 Re: Re: Pitted areas in sheet metal. in reply to rustyfarmall, 09-28-2003 07:44:34
Bondo works great or a tube of Nitro Stans spot putty which needs to dry overnight before sanding. I usually use bondo though for speed.
