Case plow color scheme
Ron
10-09-2003 04:50:29
What is the original color scheme for a Case 3 bottom pull type plow? It has round beams, rubber tires, and a mechanical lift. For any colors on the plow other than flambeau red, what is the color spec numbers?
thanks,
Ron
Bill Fuhr
07-01-2004 09:52:49
 Re: Case plow color scheme in reply to Ron, 10-09-2003 04:50:29
Does anyone have an opinion on the color scheme of a case 1-bottom plow? We have a library user trying to track that one down.
Don H
10-10-2003 18:17:12
Frame - Case Gloos red. Levers and axles - Case Implement Green. Wheels - Case Wheel Green (sort of a euclid green, but more yellow than green.
Ron
10-14-2003 16:55:44
 Re: Re: Case plow color scheme in reply to Don H, 10-10-2003 18:17:12
Don, Thanks for the color scheme. I found a good paint chip for the implement green. For the wheel green/yellow, one person suggested using Rustoleum Tan. Do you have an opinion on that?
Ron
Don H
10-15-2003 15:37:09
 Re: Re: Re: Case plow color scheme in reply to Ron, 10-14-2003 16:55:44
Ron, Send me your Email address and I'll send you a picture of the color chips for the Gloss Red, Implement Green and the Wheel Green.
Ryan Erickson
05-14-2006 10:55:01
 Re: Re: Re: Re: Case plow color scheme in reply to Don H, 10-15-2003 15:37:09
Does anyone know the paint scheme/paint codes for an old Case 2 bottom/steel wheel/ground lift plow? Best guess is it's a late 30 early 40's model.
