Painting an Alternator
Pete
10-21-2003 16:24:31
I'm converting my tractor to a 12 volt system and installing a rebuilt alternator. I was planing on using CaseIH enamel paint, but I wasn't sure what type of primer to use since the alternator is bare alumium. The CaseIH Iron/Gard red oxide primer, that I usually use, indicates that it is for fereous(sp??) metals. Any idea what primer I should use instead?
Pete
MapleStone
10-22-2003 07:19:00
 Re: Painting an Alternator in reply to Pete, 10-21-2003 16:24:31
I'm with CNKS, I would'n paint it.
Something I saw at a local car show that I thought was really neat was to polish the existing aluminum. It comes out looking like chrome.
This place (didn't get the name) had a kit of polishing products that would step you through polishing any aluminum casting and end up with a shiney piece. It then had a coating you put on it to help prevent oxidization.
It probably takes a while but would look neat.
Just a thought.
Rod (NH)
10-21-2003 22:08:58
Hi Pete,
The "proper" way to prep aluminum is with a specific acid treatment. However, that is messy and not really appropriate for an assembled alternator. Alternator surfaces are cast and usually have a somewhat rough texture. If the housing is clean (out of the box), I would just final clean with a cleaner such as PPG DX330 and prime with epoxy. If the housing is dirty or weathered, I would clean up as best I could with a wire brush to get any oxidation off, then DX330, epoxy and paint. My tendency would also be to stuff rags or something in all the normal openings to keep paint spray from the innards of the unit.
third party image Rod
CNKS
10-21-2003 19:37:01
I wouldn't paint it. It's not OEM anyway. To me they look better in their natural state. However, the spec sheet for PPG MP170 epoxy primer says it can be used over aluminum.
