Hi CNKS and Joe, Well, I am not as down on AE as the autobody shops currently are. But I am also not color-matching metallic paint on automobiles for pay. And yes, I really don't color sand and I haven't compounded anything for years so I can hardly give the best advice on it. However, I have rubbed out AE (with hardener - forget it without) years ago. I had painted one of my cars using Centari w/hardener. It was done outside in the afternoon and left outside in the evening. Big mistake. I learned the hard way not to leave fresh paint outside when there is a possibility of dew. The paint was dry to the touch OK before dark but in the morning most of the roof had lost all it's gloss and was just a haze. I didn't have an orange peel problem but I sure was upset over the haze. I used a rubbing compound on a bonnet driven by a 7" dia sander/grinder. Worked slick. Brought back the gloss and I never had any further problem with that car - held the gloss for several years until I got rid of it for other reasons. I can't remember how long it was prior to rubbing it out but is was only a couple of days or so. Certainly not weeks. A friend on mine and I did the same thing with his car (also Centari w/hard) when he a had a relatively minor orange peel problem. His was jet black and was difficult to get noticeable swirl marks out. A final power polish cured that. One problem we had with his car was slightly compounding through the black down to the primer in a couple of spots on the rain gutter ridge (got to be careful in such areas). Minor issue fixed with an artist's brush. Years ago with older materials, to be sure, but still AE and before AU was available. Actually the line between AE and AU is sometimes muddled, as with DuPont's Centari Ultra (AE field mixed as "AU"). And with PPG's earlier Delstar "Polyurethane Acrylic Enamel", normally an AE if used w/o the hardener. Semantics? Perhaps. I am not a chemist so can't address the actual chemical makeup of these but they are (were in the case of Delstar) excellent paints IMO. When I painted one of my trucks a couple of years ago, the hood wound up with a little more orange peel than I like to see. Few will ever see the truck (unregistered plow vehicle) but I was not satisfied myself. The paint was Centari Ultra and I suppose I could have bothered with color sanding and buffing but I didn't want to go to the trouble and I certainly wanted the appearance to match the rest (which was not going to get "the treatment"). It was much easier for me to simply cut down the peel with 320 on an RO sander and reshoot the hood. Problem solved. There seems to be a lot of discussion about color sanding and buffing paint nowadays, almost to the extent that it is considered necessary or desirable and is actually planned for in advance. Especially by beginners. I suspect that is somewhat due to the prevalent use of hvlp equipment and the fear of runs. HVLP is SLOW, at least compared with pressure feed non-hvlp and it is understandable that beginners can wind up not getting the paint on wet enough, resulting in poor flow out and orange peel. Orange peel is the result of improper application; either spraying technique, incorrect products for the conditions or unsatisfactory atomization (gun adjustment). While after-the-fact sanding and compounding can correct a peel condition (if the film build is enough), it really should not be relied upon as a crutch to support poor application techniques. Besides, color sanding and buffing tractor parts, with the possible exception of some flat areas, is next to impossible to do well anyway. It really is not a manual (by hand) operation. Here's my quote again: "it's a tractor not a mercedes" :o). My recommendation is to always get your confidence up by spraying test panels in the vertical position. I do that still when I use a different paint that I am not used to. Only then will you get the feel for that fairly narrow line between wet enough for no orange peel but not too wet to result in runs. It's not hard. It just takes a little practice and confidence. Don't overthink this whole thing. You will screw up occasionally, as I did with my truck hood. Take it in stride. Sand it or scuff it and reshoot, providing you used a hardener. If not, complete stripping is probably called for, unfortunately. If you don't get it right the second time, you need more practice. Unless you are doing this stuff for others for big money or are into making your tractor win prizes at shows, I would forget about color sanding and buffing. BTW, buffing is necessary after color sanding to regain the gloss, so it's a time consuming two-step process. It should not necessary for a "good" paint job. Confidence comes with practice and will, for the most part, eliminate any need for post-paint work. It's difficult to compare costs because all AE is not the same and neither is all AU. For example, DuPont Centari AE actually costs more than PPG OMNI AU as I recall. FWIW. Rod
