Quick answer please
Dave in Ohio
10-31-2003 05:42:49
It is 75* in Ohio today and perfect for painting. Question. I would like to spot paint things like the Block, head, inside frame with Dupont Centuri. Can I do this spot painting without hardner and then later cover that with same paint with hardner when I am ready to put on the final coats. Appreciate quick answer as it is a great day to paint here.
Gene B
10-31-2003 06:42:21
 Re: Quick answer please in reply to Dave in Ohio, 10-31-2003 05:42:49
Hi Dave, I would strongly suggest that you use hardener in every coat. It will dry fast and be less prone to contamination while you do your other work.
CNKS
10-31-2003 06:49:42
 Re: Re: Quick answer please in reply to Gene B, 10-31-2003 06:42:21
Agree completely. There is also a chance that the uncured, unhardened paint will lift the hardened paint above it. There is no disadvantage to using it, other than Iso's of course.
