How to Paint a tractor video
Paul (C IL)
11-04-2003 07:29:15
Has anyone here seen this video, and care to comment on the safety of the methods shown.
I purchased it with no painting experience. I was considering painting the body of a Ford 640 myself (I am taking the sheet metal to a body shop). The video made it seem possible. But after reading many of the posts here it appears that without fresh-air breathing equipment I should not attempt this project.
Just wondering if anyone here has watched the viseo.
Joe Evans
11-04-2003 19:35:08
 Re: How to Paint a tractor video in reply to Paul (C IL), 11-04-2003 07:29:15
Paul: if you've been reading these posts lately, you'll find that CNKS and I both have recently been a bit frustrated in getting a great finish on some of our projects. It CAN be done by a newbie. I'm one of them and am 'getting there' thanks to all the great help that is offered here. This is not to discourage you.
I'm with CNKS. For one tractor, take the sheetmetal to a shop, but do all or most of the prep work yourself. This is where the labor is, and this is where you'll get socked by a shop.
There is a wealth of info about prepping from the 'usual suspects' (CNKS, Rod(H), Gene, and Cliff) located in this YT section's archives. If you can't find an answer to some of you questions there, post them, and they WILL be responded to. With these guys' help and with some of my recent experience, I can even offer some answers.
One tip you will find useful: When you DO find some of the archived information, highlight the responses, copy, and then paste the text into Notepad or Word or whatever text application you have. You'll then have all the stuff in one place.
Paul (C IL)
11-05-2003 09:34:21
 Re: Re: How to Paint a tractor video in reply to Joe Evans, 11-04-2003 19:35:08
Joe:
Thanks for the info. Actually I have already decided to take all the sheet metal to a shop and have them do it.
My primary concern now is the rest of the tractor. This is an old Ford so the sheet meatal is grey and the rest is red. The good part about that is I don't rally have to worry much about color matching the autobody pro job's color.
But with all the safety issues, I am debating whether to do the red myself or farm it out also.
Money is somewhat of a factor, but I am prepared to spend a reasonable amount on the project. Ending up with over $2000 in a paint job is not really where I want to be though.
CNKS
11-04-2003 08:13:33
I have not seen that particular video, but if it comes from a person named Kevin from the Paintucation forum, it is very good. Don't use any hardeners without an air supplied system.
CNKS
11-04-2003 08:40:26
 Re: Re: How to Paint a tractor video in reply to CNKS, 11-04-2003 08:13:33
I have a bad habit of thinking I can answer a quesion without reading all of it. The video I'm referring to is about painting CARS -- but the principle is the same, just more stuff in the way.
Paul (C IL)
11-04-2003 13:40:09
 Re: Re: Re: How to Paint a tractor video in reply to CNKS, 11-04-2003 08:40:26
It is by J&D productions, First name is Dan but I cannot remember his last name. It is available by clicking on the "videos" link the left. Anyway they were using hardners, but only a cartridge type respirator. I never heard the word "isocyante" anytime.
It seems I have three legitimate choices:
1. paint w/o hardners
2. purchase several hundred dollars of safety equipment
3. Let the body shop paint everything.
At this point I am wondering which #2 or #3 will be most affordable. I want to end up with a nice looking tractor that will do some work. It was my father's since new, so there is sentimental value, but I do not expect to make it ino a parade queen by any means.
CNKS
11-04-2003 18:12:26
 Re: Re: Re: Re: How to Paint a tractor video in reply to Paul (C IL), 11-04-2003 13:40:09
The only "hardeners" that I know of that you can safely use without a supplied air system are those used with epoxy primers. PPG's are that way, don't know if DuPont, etc are the same or not. PPG uses the term "catalyst" for their MP175, I suppose to distinuish it from iso containing hardeners. A supplied air system plus paint wil set you back $700-$800 more or less, depending on which system, and how good the paint is, that does not include labor. For one tractor, you are probably better off letting someone else do it.
