Breathing Air Setup
bob
11-08-2003 21:05:27
I have two old firedept scba. (air packs)Was wondering can i hook a air line to the regulator. that would make it a positive pressure mask. would it be safe to use paint with hardener with this setup??? I can"t afford the right setup. Just wondering. THANKS for your help. bob
Jason
11-09-2003 06:11:53
 Re: Breathing Air Setup in reply to bob , 11-08-2003 21:05:27
hooking up to a regular aircompressor won't work. Contamiants in air, take a look in the archievs. What I use is also a old FD SCBA set-up, I've had the tank hydro and filled at a local dive shop. So far I've spent $30 for hydro, $15 to repair a bad oring in the gauge ( had aSCBA service tech do it )and $5 to fill it. I need to get more tanks, these only last 20-30 min good luck J
