cardinal sin-not
jf
11-19-2003 08:39:54
well I hooked up the spray gun to the compressor and painted a few items-plywood, bucket, cardboard. Looked pretty good. Not profesional but not bad. Now I think I will pursue the spray method on the tractor. Foolowing will be my steps correct if wrong Degrease and clean, sand down with 80 then 220 sandpaper, wash with thinner, then paint. I am assuming preo of other areas. What do you think
CNKS
11-19-2003 17:33:34
 Re: cardinal sin-not in reply to jf, 11-19-2003 08:39:54
Check the archives.
Bill in TN
11-19-2003 11:07:21
Maybe a good coat of primer first?
Jerry
11-24-2003 16:15:28
 Re: Re: cardinal sin-not in reply to Bill in TN, 11-19-2003 11:07:21
Maybe a couple of coats of primer with fine sanding in between. Some body filler in first to fill pits also. I also use bondo filler in between primers to fill pits.
